ACT ignition timing corrections
Posted: Mon Aug 25, 2014 11:48 am
				Hi,
I've seen that my car is always reducing ignition timing due to high ACT. In the ACT Adder table I see that it starts reducing timing at 30ºC, what is in fact a very common outside temperature here:
The IAT sensor is after the intercooler - in the intake manifold - and ACT1 is usually some 15 to 20ºC above outside temperature under boost. It makes me wonder if this table was set up for a Subaru with the IAT sensor in the stock location (reading outside temperatures and guessing the intake manifold temperatures) instead of one reading the current manifold temperature, and is consequently reducing the ignition timing too soon.
Does the table above looks correct for the sensor in the manifold? If it doesn't, could I move the corrections a bit further to reflect the readings done after the intercooler instead of outside temperature?
Thanks in advance.
Thanks in advance.
