Jumpers on the PnP board
Posted: Mon Sep 15, 2014 11:06 am
				I have some questions about the jumpers on the reverse side of the evo 8 pnp board.
SAS/EGR - Should be set to A6 for all models except EVO 7, where it may be set to D3 if a SAS solenoid is
connected to the D3 pin
What does this do? I don't have SAS or EGR on the car. Pin A6 is not in use yet on my setup.
ALM / GND - Should be CLOSED on EVO8(260) and OPEN on all other vehicles
I am using this ecu on a USDM evo 9 with a custom adapter harness, What does this Jumper actually do?
LAM HTR - Should be set to FRONT unless the rear sensor is to be used (only on EVO7 & EVO8(260)).
LAM SIG - Should be set to FRONT unless the rear sensor is to be used (only on EVO7 & EVO8(260)).
I am not using any of the stock O2 sensors on the car, only the NTK UEGO. So can I leave them to FRONT, or remove the joint?
