Just basic wiring help!
Posted: Fri Oct 24, 2014 10:33 pm
				Hello!
I'm using an s6 ecu and wanted to run a wasted spark ignition system as it'll keep things simpler. Can I do this by supplying a 12 volt feed and use coil signals for cylinders 1 and 2 to activate the coil?
Second question, are the two pin wheel speed sensors called vr sensors? And would I use a bipolar input and earth it through the ecu and assign the pin for wheel speed?
Thanks in advance
Phil
Thanks in advance
Phil
