Cruise control for Subaru Hatch S6GP PnP
Posted: Sat Nov 01, 2014 6:39 pm
				I have a Subaru Hatch STi and I recently got the S6GP PnP for the car.
From my understanding, to get the cruise control to work, I need a cruise control button and an input to a brake pressure.
I tried to get the Cruise control working by doing the following:
a) Fabricated a button (I'm using an aftermarket steering wheel) for the cruise control and connected it to the roll connector. (Cruise and Cancel wires)
b) From the ECU Harness (lets call it connecter B) I wired the cruise and cancel wires to the pins 4 and 10 of the 12 pin molex
c) Since I'm already using the Lam V, I wired pin 28 (B28) of connector B (Brake switch input) to AN4 via the 12 pin molex and set Brake Pressure (Front) input to AN4
d) In Sensors, I set up Brake Pressure (Front) in a way that if I step on the brakes, it should exceed the max brake pressure set in cruise control and it'll cut out.
Monitoring the input V values, I verified that the inputs are wired properly and proceeded to test to see if I can get cruise control to work.
Then I noticed something:
i) When I pressed the cruise control button, cruiseActive is still Idle and cruiseDisableCause is Lateral Acceleration (?!)
ii) I keep getting Voltage Limit and Voltage Range Errors for the Brake Pressure (Front). Then I realised that B28 is a 12 V output and AN4 is only a bipolar 5V input.
So at this point I presume that my problem is mainly (ii). So may I know if there's any PROPER way to convert the 12V input to 5V?
My current idea is this:
A) Get a 12V to 5V convertor (for USB chargers)
Brake input -> 12V in
ECU/Power gnd -> 12V gnd
5V out -> AN4
5V gnd -> sensor gnd ?!? (aka pin 10 of 12 pin molex)
I hope what I'm saying makes sense. If there's a better idea of getting the cruise control to work (e.g. carry a brick in the car), do let me know.
5V out -> AN4
