Help with comms plug pin numbering
Hi I am trying to wire up the bluetooth module on s6PNP on my type r. As I look into the ECU at the comms plug which are pins 1 and 2?
						Re: Help with comms plug pin numbering
Not sure of the orientation of the socket on the PnP board, but if you take the mating connector that you will plug in to the ECU, with the latching tab at the top, then pin 1 is on the left:
Cheer Tim that's the ethernet plug in that image. It's the 6 pin 'comms' socket I am interested in per the pinout guide on the forum in order to wire in the blue tooth module. There is no numbering on the plug I am using as to which pin relates to which number.
http://www.syvecs.co.uk/forum/viewtopic ... 352b460d7e
No, that's the plug for the comms socket, not an Ethernet connector.
It's pins 1 and 2 of the following socket I am trying to identify
Comms :
Pin 1 - RS232 RX
Pin 2 - RS232 TX
Pin 3 - Comms GND
Pin 4 - CAN HI
Pin 5 - CAN LO
Pin 6 - Power GND
 Comms :
Pin 1 - RS232 RX
Pin 2 - RS232 TX
Pin 3 - Comms GND
Pin 4 - CAN HI
Pin 5 - CAN LO
Pin 6 - Power GND
Er...yes...I KNOW!!! The answer's in the picture of the RJ25 connector I posted (it is not a a picture of Ethernet plug).
Thanks Tim - Sorry I'm a trifle confused as you can see. I'll give that a go
LOL no problem.
Have you got a cable with an RJ12 plug on? Just be aware that many modem or telephone type plugs only have the middle 4 pins populated, so you won't be able to access pin 1 if you use one of those.
