				Pat - S6 and Wiring Harness
				Posted: Sun Nov 16, 2008 6:27 pm
				by WUZ
				Pat - the ECU and V5-6 Specific wiring harness arrived a couple of days back (Harness wiring looks great) and I can see what one is the CAN Cable........................ but what are the other cables for?
Need to get this wired in sooner rather than later. Any chance of a Wiring Description/Diagram?
Cheers!
Russell
ps - this ECU is supposed to have FULL KNOCK CONTROL (optional extra which I paid for) but as this isn't the ECU originally ordered
 Can I assume it still has this optional feature enabled?
				Re: Pat - S6 and Wiring Harness
				Posted: Mon Nov 17, 2008 12:10 am
				by Charlie
				Hi Wuz,
I've attacted the pin out of an S6GP, Pat made the loom adaptor so I will draw his attention to this thread so he may help further
Charlie
				Posted: Mon Nov 17, 2008 8:16 am
				by greenamex2
				Cheers, also answered a silly question I had!
				Posted: Mon Nov 17, 2008 5:35 pm
				by WUZ
				Thanks Charlie............. remind him that the ECU supplier informed me that I was supposed to get the MAP sensor as well as that was paid for?
Russell
				Posted: Mon Nov 17, 2008 8:11 pm
				by Charlie
				If you have paid for a map sensor Wuz i shall make sure you get one
Charlie
				Posted: Tue Nov 18, 2008 5:55 pm
				by WUZ
				Charlie, FYI Mark @ Lateral is the supplier of the ECU (with FULL Knock control option) and Map sensor.
				Posted: Tue Nov 18, 2008 11:46 pm
				by Charlie
				Wuz, I've checked and the ECU you have has the full knock control enabled. Also Pat should be along shortly to help with your other questions.
Charlie
				Posted: Wed Nov 19, 2008 6:05 pm
				by WUZ
 Happy days!
Russell
				Posted: Fri Nov 21, 2008 12:35 pm
				Russell,
As Charlie has already pointed out, the ECU I sent has full knock, just as you ordered
 I sent a base calibration with the correct I/O assignment to Andy, but I guess he didn't forward a copy to you, so I'll PM it to you after I post this
The additional wires in the loom are for the NTK wideband lambda sensor, Calibration switch and an ALS arm input. If memory serves I have the launch control input wired up to the neutral posisition switch, ie as soon as you pop it in gear it arms
 I'll double check my wiring schedule though and send that to you separately.
