Streaming query
Streaming query
I think I know part of the answer, but will ask anyway.
In order to stream, the ecu logging parameters must already been reached before you can turn on streaming via SData ?
And if the ecu drops out of internal logging mode...it shuts down ?
It would then need to be manually restarted again ?
With the new burst options etc.
When streaming, what is being logged ? base only, or is logging exactly as it would be on the ecu via SCfg, base/enhanced/high/traction burst etc etc, just now effectively you have unlimited memory ?
So in theory I could just enable base with lots of items at high logging rates, and log them all the time a PC is connected ? and ignore burst logging ?
So if wanting to log lots...bang a cheap netbook or laptop in somewhere and let it work away ?
Re: Streaming query
Its logs everything as set in Scfg and also using the burst logging modes. Just gives you as much memory as your laptop has available :)
Re: Streaming query
Ryan.g wrote:Its logs everything as set in Scfg and also using the burst logging modes. Just gives you as much memory as your laptop has available :)
Thanks Ryan.
But really with almost infinite memory, you could just go nuts and log all the important things at a high rate, all the time ?
Just need to decide on a cheap netbook type device for handiness.
