				Syvecs App Calculations Talk
				Posted: Sun Oct 11, 2015 11:04 am
				by Wez
				Hey All,
A new topic dedicated to the discussion of calculations within the App, post your findings on what works best for you, I pull some data across from the other threads to get this going.
FYI The app runs separate from the ECU, the datastream output is always the same unit regardless what unit you display within sCal, you can see this at the top of the datastream frame content window, the calc does not change even you select another unit type.
				Re: Syvecs App Calculations Talk
				Posted: Sun Oct 11, 2015 11:08 am
				by Wez
				To convert Lambda to AFR
The current calc for displaying Lambda is shown below as per sCal :-
(x/1000)+0
You could use the following calc to convert into AFR :-
x*0.0147
I have not tested these myself but they should get you pretty close
				Posted: Sun Oct 11, 2015 11:10 am
				by Wez
				Pressure Reading Conversions
OK looking at a MAP value the default is in mBar like all pressure readings, the default calc is :-
(1*x)+0 which is basically just x
To convert to PSI one mBar is equal to 0.0145037738, I would round this up to 0.0145 and use the following calc :-
x*0.0145
To convert to BAR use x*0.001
If you want KPA you could use x*0.1
				Posted: Sun Oct 11, 2015 11:12 am
				by Wez
				Convert Default Celsius to Fahrenheit
Big thanks to JamesD for this
Just as a quick note, for the conversion you would want to use
Before: (x/10)+0
After: 1.8*(x/10) + 32
for the conversion from Celsius to Fahrenheit as the function has both a slope and offset so TempF = 1.8*TempC + 32.
				Posted: Sun Oct 11, 2015 11:16 am
				by Wez
				Speed Unit Conversion - Default KPH
For KPH into MPH, sCal shows vehicleSpeed calc as below and output unit is KPH :-
(0.036*x)+0
According to Google the conversion of KPH into MPH is KPH * 0.621371, therefore you could do (0.036*x)*0.621371 but it looks messy.
You could also do this :-
x/45 which gets you damn close, see below calcs :-
Example 1 x = 1000 (raw value)
(0.036*1000)+0 = 36 KPH
36KPH * 0.621371 = 22MPH
1000 / 45 = 22MPH
Example 2 x = 2300 (raw value)
(0.036*2300)+0 = 83 KPH
83KPH * 0.621371 = 51MPH
2300 / 45 = 51MPH
I would try with the very basic calc of x/45 and see how that looks
Again this is untested but should be OK, let me know how you get on
