Oh I hadn't thought of that. I'll try that, thanks!Wez wrote:The best way to check sensors would be to compare what is displayed in sCal to what you are seeing on the App, it should be the same as long as the calcs are correct.
Indeed I am. I downloaded it onto my Note 3 a while back but hadn't done much with it. I did notice that it rotates on the phone, but I don't rotate the CarPC so I hadn't tried it. I could try that and see what happens, but I figured it was just a limitation of the stereo itself. I don't see why they'd add rotation to the features haha. The ad says it's running Android 4.4, which is what I looked for specifically after reading one of the Android threads here.Wez wrote:Are you referring to the Android BETA App?
If so it does support rotation and works in all orientations when used on a phone or tablet, do you know what version of Android is running on the CarPC?
Its possible that the CarPC might be presenting the orientation incorrectly, I could look at including a locked landscape setting or maybe roll out a CarPC version, what CarPC are you using?
I'm pretty sure it is presenting it incorrectly, yes. It's a Chinese unit from eBay haha. It's pretty impressive for the price though, it has pretty much everything I wanted and it was the only thing I found that I knew for sure had Android and I couldn't find anything running a Mac OS and I didn't feel like rigging the iPad to work for it. I figured for the price I could chance that it wouldn't work with the app. This is the exact one I got.
http://www.ebay.com/itm/CAPACITIVE-7-An ... rmvSB=true
