Hi - I'm looking for a solid state fluid pressure sensor to for fuel pressure - the Stack ST747 *seems* to fit the bill - but I can't find a great deal of technical info on it.
Can anyone advice as to whether or not it'd be compatible with the S6plus?
Ed.
Stack ST747 pressure sensor
Re: Stack ST747 pressure sensor
As long as it's a 5v powered 0-5v out then no reason why not.
What's difference between it and the likes of this ?
http://www.jti.uk.com/product/10-bar-fl ... e-sensors/
Well, comparing the spec of the Stack vs. the KA sensor that we sell:
There are many pressure sensor out there with a superficially similar spec - I have sold 100's and 100's of the KA 10 bar sensor and only ever had one fail, due to excessive vibration as it was mounted direct to the block of a 1970's Lotus engine.
- The stack is less accurate (2% vs 0.5%)
- has a lower maximum working temperature (120 vs 130)
- has a slightly better minimum working temperature (-30 vs -20)
- has a poorer IP rating (IP65 vs IP67)
- has a slightly less common connector (mini sure seal vs. Metripack 150)
- doesn't state if the seals are OK in the presence of methanol/ethanol - the KA is fine.
- is, I imagine, more expensive!
Thanks Stevie, Thanks Tim - order for the KA unit - order coming your way!
