				Secondary injectors setup
				Posted: Sun Jun 26, 2016 4:19 pm
				by HondaDrag
				Hi, I installed another set of injectors to a total of 8 2200cc injectors on a 4 cylinder turbocharged drag engine and configured the IO configuration.
Now how do the maps secondary load injection maps and secondary load injection time blend work exactely as i am confused abit.
Since one of the maps is tps based and the other MAP but as percentage.
Please can you clarify.
Can i configure them as such that at a certain duty cycle i start the secondarys?
Thanks alot for help
				Re: Secondary injectors setup
				Posted: Mon Jun 27, 2016 6:05 am
				I set up a word document on how to do this correctly after seeing quite a few people stuff this up (specially when using different primary and secondary injectors). Though its all explained well under F1 help, after you read that if you still are unsure then pm/email me and I will pass it on.
I think? you may be getting confused with the Secondary Load Injection Time & Blend maps under the Run Mode Fueling tab? If so this is a
secondary load source and not talking about secondary fuel injectors
 I see how you got that confused though!
So clearing up the "TPS and the other is MAP" mis understanding its just simply this below.....
Obviously you have to assign the extra injectors in your I/O, 2 rotor version below for example
Being two sets of 4 x 2200cc injectors your case is simple.
Secondary Injector Scaling 2200/2200 =
1
Fuel Split is defined as Primary/(Primary+Secondary) 2200/(2200+2200) = 0.50 (50%)
So you can blend in the map as such
Under Corrections
set up your
Secondary Injector Hold Time Minimum
Secondary Injector Opening Time-f(vbat) < this you can SA cntrl C ( short cut for Select,All, control key+Copy) from the Primary Injector Opening Time-f(vbat) table since you are using the same injectors
				Posted: Mon Jun 27, 2016 12:46 pm
				Basically as above.
If you wanted, you could change the blend start slightly higher than 1000mbar ( or anywhere you wanted really )
0% in the table would be primaries only.
50% in table will be even split over both
100% in the table would be secondaries only
				Posted: Mon Jun 27, 2016 9:00 pm
				by HondaDrag
				Ok, now all make sense, Thanks Rice racing great post
So the maps i mentioned are not used in my case.
The injector split 1 map is used to command when they start to inject but still the overall fueling are from the Base Injection time 1,2..etc maps..
And thanks to Stevie_turbo also for more clarification and yes on the injector split i think i will start at 200kpa onwards.
One question what are Primary/Secondary Injector Hold Time Minimun used for?
Thanks alot.
				Posted: Mon Jun 27, 2016 11:28 pm
				Answered below
HondaDrag wrote:Ok, now all make sense, Thanks Rice racing great post
*Correct*
*Yes, when they start and what proportion is sent to each, make them equal as defined by the ratio*
*You can start them as low as is defined by the minimum open time for the secondary and primary, I have software that shows all this and effect on 'effective' base fuel map, more correctly 'fuel final' so can easily show you how it will work.I start them earlier and lower down for various reasons I'll tell you in private
*As it states, minimum time for them to work send me an email and I will explain in depth if you like or just change your cal and you can see the changes to make it easier for you*
Thanks alot.
				Posted: Fri Dec 23, 2016 1:03 am
				by ciphermonk
				In the situation where you are switching from 550cc secondary injectors to 1000cc secondary injectors, what changes need to be made in the calibration other than Secondary Injector Opening Time to compensate for the larger injectors?
Been looking through the calibration trying to find out if there's anywhere else that injectors are characterized.
				Posted: Fri Dec 23, 2016 9:30 am
				ciphermonk wrote:In the situation where you are switching from 550cc secondary injectors to 1000cc secondary injectors, what changes need to be made in the calibration other than Secondary Injector Opening Time to compensate for the larger injectors?
Change the ratio of primary to secondary injector size, secondary multiplier.
So if this had been 1, ie primary and secondary were same size before, change this value to approx 0.5 as the primaries are now half the size of the secondary.
And obviously injector dead times etc etc and usual tuning stuff incl whatever transition and split you may want the secondaries to be doing.
But that should be a close starting point.
				Posted: Fri Dec 23, 2016 4:05 pm
				by ciphermonk
				stevieturbo wrote:ciphermonk wrote:In the situation where you are switching from 550cc secondary injectors to 1000cc secondary injectors, what changes need to be made in the calibration other than Secondary Injector Opening Time to compensate for the larger injectors?
Thank you Stevie.
Right now the value is set to 1.2 which seems low considering that the direct injectors are in the neighborhood of 1200cc.
				Posted: Fri Dec 23, 2016 4:39 pm
				ciphermonk wrote:stevieturbo wrote:ciphermonk wrote:In the situation where you are switching from 550cc secondary injectors to 1000cc secondary injectors, what changes need to be made in the calibration other than Secondary Injector Opening Time to compensate for the larger injectors?
Thank you Stevie.
So you had 1200cc primaries and 550cc secondaries  before ?
I guess you could try and use a value that would minimise re-tuning, but it would be better for the numbers to make sense with regards the actual sizes used.
You'll need to completely go over the fuel table tuning again
				Posted: Tue Feb 14, 2017 2:38 am
				by ciphermonk
				For those of you that are blending DI and Port injection in a turbocharged application, what is the maximum that you bring in the port injectors in high load areas?
