				Wireing avcs into a version 4
				Posted: Tue Jul 04, 2017 5:46 pm
				by p555sbr
				does anybody know which pins on the standard version 4 ecu plug we connect the avcs wires to heads are 3pin 2.5 avcs wiring harness is from jt innovations and the ecu is a s6 pnp thanks Dave
				Re: Wireing avcs into a version 4
				Posted: Tue Jul 04, 2017 6:06 pm
				When supplied it would have had a wiring information sheet. In lieu of that (and because I haven't put them on the website) download the sensor datasheet - perhaps not well named - from our website
here. It has suggested pins for sensors and AVCS.
Note that the 3 pin cam sensors need a 12V power supply and a ground connection, and will need a pull up enabled on the inputs.
