Page 1 of 2
				dbw module wiring
				Posted: Sat Aug 05, 2017 5:32 pm
				by madships
				I appear to be having some snags with the dbw module- looking at the wiring info given on the site, I should wire up the control signal to S1 from one of the ign sources, and from the dbw help video it states the S6 should be set to half bridge mode when using the external DBW module. However when I try to set this up in SCal, I get told that the pin does not support the required output ability- obviously I am missing something? does there need to be a signal to S2 as well? should it not be run in half bridge mode? or is it something in SCal I am missing? any help greatly appreciated!
				Re: dbw module wiring
				Posted: Sat Aug 05, 2017 7:36 pm
				Set it low side and make sure the DBW unit has a resistor between the S1 pin and the 5V terminal in the unit.
Or, if you use an IGN output, you don't need the resistor.
The DBW box "trigger" needs a 0-5V switching signal.
See
here
				Exactly what DBW module or controller are you using ?
The little external box would usually be configured as low side for the output on the ecu, not half bridge.
				Posted: Sat Aug 05, 2017 7:38 pm
				stevieturbo wrote:Exactly what DBW module or controller are you using ?
The reference to "S1" 99% implies it's the module in the black plastic box
				Posted: Sat Aug 05, 2017 10:01 pm
				TimH wrote:stevieturbo wrote:Exactly what DBW module or controller are you using ?
Sometimes you just never know what's in that 1% though !! lol
				Posted: Sat Aug 05, 2017 10:08 pm
				by Slowie
				As per TimH, if you have the Syvecs supplied DBW driver, setup the output to Low Side.
It is an error in the video, or the info changed since the vid was made some time ago.
				Posted: Sun Aug 06, 2017 12:04 pm
				by madships
				thanks, It serves me right for blindly following the video- I have the syvecs dbw driver, and low side makes more sense.I am driving it with a spare ign, so everything should work fine now.  as an aside, what is S2 on the dbw driver used for?
				Posted: Sun Aug 06, 2017 12:08 pm
				madships wrote: as an aside, what is S2 on the dbw driver used for?
Nothing! Nor do the DIP switches.
The module is bought in as a generic module but flashed with code specifically for, and dedicated to being, a DBW controller.
				Posted: Sun Aug 06, 2017 12:09 pm
				And as an aside - an memory jog to myself! - a few years ago a wrote code for this same module to be a power steering controller for Supra's to allow you to adjust the steering weight as desired. Must get around to finishing it!
				Posted: Mon Aug 07, 2017 6:31 pm
				by madships
				ok, before I start chasing up wiring issues, I thought I should sanity check with others. the syvecs DBW module- M1 and M2 definitely go to the same motor- I have it set up like this at the moment, but whilst there is a drive signal going to the throttle, the throttle isnt moving, and the voltage at both m1 and m2 is reading the same- so I assume they are sending the same on signal- surely these should be out of phase with each other? this is on a LS3 throttle by the way, if it helps identify possible issues.
