LOW LOAD CUT adder (full auto gear control)
Posted: Wed Oct 25, 2017 11:34 am
				hello, would be nice to be able to switch between either pps or manifold pressure for the low load gear cut threshold for turbo charged engines.
eg: say low load cut is 20% throttle. going up a hill or constant 20% is enough to build boost slowly, to the point where the low load cut severity fuel cut isn't sufficient, but the closed loop main cut is to severe
OR have a manifold pressure adder to the main cut TO MODIFY THE SEVERITY ( street driven sequential gearbox with paddle shift)
basically some kind of manifold pressure adder to be able to fine tune the main cut in the low boost/moderate engine torque areas. but not wide open 800hp etc etc.
or i have the wrong idea/haven't worked out how to implement all the ramp in/out strategies yet...
Dave.
Dave.
